Langue
GoodWe’s hybrid inverters ET and EH series and the AC-coupled retrofit inverters BT and BH series are the first inverters to pass compatibility tests with the BYD Battery-Box Premium HVM. This now allows GoodWe to cater for a bigger slice of the pie.
GoodWe Storage Solution
GoodWe has the most comprehensive storage portfolio in the industry, including European brands, covering single-phase, three-phase, high voltage and low voltage. GoodWe invests a lot on researching and developing storage solutions in different application scenarios and has massive potential in the storage sector. In markets where electricity prices are high such as Italy, an increasing number of residents prefer to install hybrid inverters due to FIT and high electricity bills, with the intention to maximize self-consumption. GoodWe’s backup function ensures steady 24-hour power supply in extreme weather conditions. While in countries where grids are unreliable or in poor condition, the Hybrid systems are the best alternative for self-sufficiency. The market is hungry for storage and GoodWe has the ingredients.
Name of Inverter: GoodWe ET Series, Three-phase Energy Storage Inverter, Dual-MPPT
Unique Selling Points:
Maximum efficiency up to 98.2%
Uninterruptible Power Supply
Wide battery voltage range
Fanless design, quiet operation
Name of Inverter: GoodWe EH Series, Single-phase Energy Storage Inverter, Dual-MPPT
UPS function (uninterruptible power supply)
High voltage battery (180-600V)
10% AC output overloading
Battery input reverse polarity protection
Name of Inverter: GoodWe BH Series, AC-Coupled Retrofit Inverter, 3-6kW
UPS automatic switch in 10ms
Maximize self-consumption
Pre-wired, plug & play
Recommandé
