EHB Series
(South Africa only) 5-10 kW | Single phase | up to 4 MPPTs | Hybrid inverter (HV)
TÉLÉCHARGER LE PDF >>
Faire défiler
undefined
UPS-level switching
AC bypass
Strong backup
<10 ms UPS-level Switching
AC bypass switch
AFCI ready & rapid shutdown
Strong backup power supply
Well-designed integrated architecture
4 MPPTs – higher yields
undefined
UPS-level switching
AC bypass
Strong backup
Featuring 4 MPPTs, the EHB (5-10 kW) is the perfect solution to feed solar power to large residential properties, offering you more choices and maximizing total solar generation.
Installer-friendly
Modèle
GW5000-EHB
80~495
50/50
13/13/13
Modèle
GW6500-EHB
80~495
50/50
13/13/13/13
6500
6500
Modèle
GW8600-EHB
80~495
50/50
13/13/13/13
8600
8600
Modèle
GW0010-EHB
80~495
50/50
13/13/13/13
10000
10000
Détaillant
Utilisateur final
Autres
Installateur
